VB Macro for External Links
Hey guys,
Did some digging around and can't find a good solution for this. Maybe there isn't one...
To explain, I need some sort of macro that will update all external links. We have machine files that are only accessed by our CNC programmers. They are not well versed with Catia and do not remember to check all pointed documents and external links. This is becoming a large problem.
Essentially, I want to check all links in the product, then update/load them if necessary.
Thanks guys!
Thanks guys!
RE: VB Macro for External Links
If you don't have any other (good) solution, you'll need a macro to batch open CATIA files, force update and save those files...don't remember if is something existing in that utility tool...
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Any resources that you think I can look into?
Anyway, there is a very good article on Mike's blog about batch process, can give you some ideas.
Fernando
