Stuck in Drafting
Stuck in Drafting
For some reason when I got back to my drawing, the dimension I'll define makes no sense. See att. Here, I put a dimension in a place I've already done so. The original measurement was 21 inches, and now the same length is defined as 8.4. I used the same points, and haven't messed with any of the units settings. I dont see the link between 21 and 8.4 so I don't see it as a conversion issue. I can't move forward until I figure this out. Thanks!
RE: Stuck in Drafting
if any geometry has been created on the drawing on top of the view and the scale of the view is not 1/1 it can cause some headaches.
the reason I ask is that 8.4 X 2.5 = 21.0
Have had this happen occasionally in the past 31 years of UG experience with inexperienced operators.
see my attachment. Hope this helps fix the problem or at least you will be aware if you get similar results sometime and this can be a possible solution.
Wayne Huseby
Drafting Checker
Goodrich Corp
Jamestown, ND 58401
another possibility is if reference sets are used change reference sets so the sketch does not show or move the sketch to another layer and make that layer invisible in the view. Hard to say exactly what to do without seeing the actual file to view the sketch. glad I was able to help somewhat. let me know your solution if you would.
Wayne Huseby
Drafting Checker
Goodrich Corp
Jamestown, ND 58401
Wayne Huseby
Drafting Checker/Drafter
United Technologies Aerospace Systems
Jamestown, ND 58401
