SPA / DMU sectioning issue
As of today, my DMU (SPA license) sectioning results have changed...and not for the better.
Is there a CATSetting that effects the results of sectioning. Just last week, when I sectioned a CATProduct, each component sectioned in the color of the solid model. Now everything is sectioning in a shade of green, as though I am not using the SPA license. The image on the left is how my sections appeared last week and the image on the right is what I am seeing today. As far as I know, I have not changed any settings.
Also, all the parts in contact appear to be merged together into one solid.
See attached pic
See attached pic
RE: SPA / DMU sectioning issue
Tools > Options > Mechanical Design > Assembly Design > DMU Sectioning tab
Also, did you change the background color?
Are you in "Swap visible space"?
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
I have not changed the background color.
Where do I check the "Swap visible space"?
When you're in the process of a section cut there is a button along the bottom of the CATIA toolbar that let's you swap from what's in the visible space to what's in the hidden space. If you click that button usually the background color goes to a light green/blue or turquoise as you have shown in your screen grab.
Drew Mumaw
www.drewmumaw.com
Drew Mumaw
www.drewmumaw.com
