Section line segment rotation
Hi All,
Is there any other way than "unfolded view" option to rotate single segment of section line. I cant use resolve section as well. Using NX-8.5.3.3
Thanks in advance
Dnyanesh
RE: Section line segment rotation
Can you describe/ illustrate what it is you are trying to do ?
Is this according to a drafting standard ?
Tomas
Hello Tomas,
I am trying to explore if there is such option in NX drafting.
I want to create section view with 6 to 7 segments, out of which at least one segment is inclined (angle).
I don't have fair idea if its according to drafting standards or not :(
Hi All,
Using "Folded View" option is fine for me, but problem in that is it will give different hatching lines for the same part.
Folded view changes hatching line angle for every segment which results in showing two different hatchings for single part/body.
If hatchings can be kept as normal/default like we see in other views without manually editing hatch angle then its fine for me.
Let me know anyone if you have known way to do that.
Dnyanesh
