Historical OWJ
Historical OWJ
I have the SJI 85-year catalog at the office, but trying to answer something today.
36' long, 24" OWJ, c-1950's (although 60's possible). Webs are 3/4" rounds with panel points at 24" o.c. Top and Bottom chords are 4" wide (x 1 1/2) bulbed-hat channel type shape (not solid bulb, the 7/32" flat plate is rounded in the middle so it looks like 1 1/4" flat, 1 1/2" semi circle, 1 1/4" flat). I believe this is an SJ or S joist (2 1/2" bearing). I calculate appx. 390 plf capacity, but this is much higher than current K-joist capacities. Anyone have access to the tables that can provide me with the allowable TL/LL for 24" joist? (obviously, there will be a few since we don't know actual chord designation). Thank you.
RE: Historical OWJ
They are no longer in business, but I have a catalog at work.
I think Sliderule may also hand the catalog on his site.
BAretired has one too.
Mike McCann, PE, SE (WA)
RE: Historical OWJ
RE: Historical OWJ
RE: Historical OWJ
RE: Historical OWJ
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
