Calculating CFM from PSI
How do I calculate compressed air flow rate in CFM using diameter of pipe, density of air, temperature of air, and pressure of air at drop station? I used the equation Q= (area^2)* sqrt((2*pressure/density)) but my result is not matching with the graph shown in the link below.
http://www.engineeringtoolbox.com/air-flow-compres...
RE: Calculating CFM from PSI
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
David Simpson, PE
