Dealing with hide/show in drawing
Probably everyone came across this issue. Once i hide a body/open body in a catpart i don't want this to disappear from a drawing view.
Usually we don't use multi bodies parts except complex sheet metal parts or machined parts where i have to show several stages of manufacturing process like first bend, second and so on. In this case i don't want to use assembly and manage representation. How to keep hidden body always in show state in a drawing during update? I don't want to isolate a view.
Any ideas will be appreciated.
RE: Dealing with hide/show in drawing
you can link the view to only the bodies you want. So if you have 3 bodies, you can link the view to let say body.1
you can pla with show no show of body.2 or body.3 this will never ask for view update.
Eric N.
linking to a body i want to see will not prevent a view from disappearing if i will hide it in part design environment.
instead of using hide show can you use layers and filters? This should not affect drawing views.
Eric N.
