attribute windows . need another row
thread561-353249: Windows edit attribute
i need to add another row attribute to this useful journal
but i haven't stand a chance to make by myself.
from cowsky:
'NXJournaling.com
'NX 7.5, will error on NX8 or above because "MATERIAL" attribute is now reserved
'A quick example of how to show an attribute value in a textbox.
'ref eng-tips thread561-332871: Journal - Show Attribute Value on TextBox (User Form): Journal - Show Attribute Value on TextBox (User Form): Journal - Show Attribute Value on TextBox (User Form)
'eng-tips thread561-353249: Windows edit attribute: Windows edit attribute: Windows edit attribute
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
Dim theSession As Session = Session.GetSession()
Public workPart As Part = theSession.Parts.Work
Sub Main()
Dim myDialog As New Dialog1
myDialog.myPart = workPart.FullPath
myDialog.ShowDialog()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Public Class Dialog1
Public myPart As String
Private myAttributeTitle(2) As String
Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Try
workPart.SetAttribute(myAttributeTitle(0), TextBox1.Text)
Catch ex As Exception
MsgBox(myAttributeTitle(0) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(1), TextBox2.Text)
MsgBox(myAttributeTitle(1) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(2), TextBox3.Text)
MsgBox(myAttributeTitle(2) & " : " & ex.Message)
End Try
Me.Close()
End Sub
Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
Private Sub Dialog1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Me.Text = myPart
myAttributeTitle(0) = "CATALOG"
myAttributeTitle(1) = "MATERIAL"
myAttributeTitle(2) = "MW_STOCK_SIZE"
Try
TextBox1.Text = workPart.GetStringAttribute(myAttributeTitle(0))
Catch ex As ApplicationException
'attribute does not exist
TextBox1.Text = ""
End Try
Label1.Text = myAttributeTitle(0)
Try
TextBox2.Text = workPart.GetStringAttribute(myAttributeTitle(1))
TextBox2.Text = ""
End Try
Label2.Text = myAttributeTitle(1)
Try
TextBox3.Text = workPart.GetStringAttribute(myAttributeTitle(2))
TextBox3.Text = ""
End Try
Label3.Text = myAttributeTitle(2)
End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Dialog1
Inherits System.Windows.Forms.Form
'Form overrides dispose to clean up the component list.
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Me.TableLayoutPanel1 = New System.Windows.Forms.TableLayoutPanel()
Me.OK_Button = New System.Windows.Forms.Button()
Me.Cancel_Button = New System.Windows.Forms.Button()
Me.Label1 = New System.Windows.Forms.Label()
Me.TextBox1 = New System.Windows.Forms.TextBox()
Me.TextBox2 = New System.Windows.Forms.TextBox()
Me.Label2 = New System.Windows.Forms.Label()
Me.TextBox3 = New System.Windows.Forms.TextBox()
Me.Label3 = New System.Windows.Forms.Label()
Me.TableLayoutPanel1.SuspendLayout()
Me.SuspendLayout()
'TableLayoutPanel1
Me.TableLayoutPanel1.Anchor = CType((System.Windows.Forms.AnchorStyles.Bottom Or System.Windows.Forms.AnchorStyles.Right), System.Windows.Forms.AnchorStyles)
Me.TableLayoutPanel1.ColumnCount = 2
Me.TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Controls.Add(Me.OK_Button, 0, 0)
Me.TableLayoutPanel1.Controls.Add(Me.Cancel_Button, 1, 0)
Me.TableLayoutPanel1.Location = New System.Drawing.Point(277, 122)
Me.TableLayoutPanel1.Name = "TableLayoutPanel1"
Me.TableLayoutPanel1.RowCount = 1
Me.TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Size = New System.Drawing.Size(146, 29)
Me.TableLayoutPanel1.TabIndex = 0
'OK_Button
Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.OK_Button.Location = New System.Drawing.Point(3, 3)
Me.OK_Button.Name = "OK_Button"
Me.OK_Button.Size = New System.Drawing.Size(67, 23)
Me.OK_Button.TabIndex = 0
Me.OK_Button.Text = "OK"
'Cancel_Button
Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Cancel_Button.Location = New System.Drawing.Point(76, 3)
Me.Cancel_Button.Name = "Cancel_Button"
Me.Cancel_Button.Size = New System.Drawing.Size(67, 23)
Me.Cancel_Button.TabIndex = 1
Me.Cancel_Button.Text = "Cancel"
'Label1
Me.Label1.Location = New System.Drawing.Point(9, 19)
Me.Label1.Name = "Label1"
Me.Label1.Size = New System.Drawing.Size(134, 26)
Me.Label1.TabIndex = 1
Me.Label1.Text = "Attribute:"
Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox1
Me.TextBox1.Location = New System.Drawing.Point(149, 23)
Me.TextBox1.Name = "TextBox1"
Me.TextBox1.Size = New System.Drawing.Size(234, 20)
Me.TextBox1.TabIndex = 2
'TextBox2
Me.TextBox2.Location = New System.Drawing.Point(149, 49)
Me.TextBox2.Name = "TextBox2"
Me.TextBox2.Size = New System.Drawing.Size(234, 20)
Me.TextBox2.TabIndex = 4
'Label2
Me.Label2.Location = New System.Drawing.Point(9, 45)
Me.Label2.Name = "Label2"
Me.Label2.Size = New System.Drawing.Size(134, 26)
Me.Label2.TabIndex = 3
Me.Label2.Text = "Attribute:"
Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox3
Me.TextBox3.Location = New System.Drawing.Point(149, 75)
Me.TextBox3.Name = "TextBox3"
Me.TextBox3.Size = New System.Drawing.Size(234, 20)
Me.TextBox3.TabIndex = 6
'Label3
Me.Label3.Location = New System.Drawing.Point(9, 71)
Me.Label3.Name = "Label3"
Me.Label3.Size = New System.Drawing.Size(134, 26)
Me.Label3.TabIndex = 5
Me.Label3.Text = "Attribute:"
Me.Label3.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Dialog1
Me.AcceptButton = Me.OK_Button
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.Cancel_Button
Me.ClientSize = New System.Drawing.Size(435, 163)
Me.Controls.Add(Me.TextBox3)
Me.Controls.Add(Me.Label3)
Me.Controls.Add(Me.TextBox2)
Me.Controls.Add(Me.Label2)
Me.Controls.Add(Me.TextBox1)
Me.Controls.Add(Me.Label1)
Me.Controls.Add(Me.TableLayoutPanel1)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "Dialog1"
Me.ShowInTaskbar = False
Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
Me.Text = "Dialog1"
Me.TableLayoutPanel1.ResumeLayout(False)
Me.ResumeLayout(False)
Me.PerformLayout()
End Sub
Friend WithEvents TableLayoutPanel1 As System.Windows.Forms.TableLayoutPanel
Friend WithEvents OK_Button As System.Windows.Forms.Button
Friend WithEvents Cancel_Button As System.Windows.Forms.Button
Friend WithEvents Label1 As System.Windows.Forms.Label
Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
Friend WithEvents Label2 As System.Windows.Forms.Label
Friend WithEvents TextBox3 As System.Windows.Forms.TextBox
Friend WithEvents Label3 As System.Windows.Forms.Label
End Class
from cowsky:
'NXJournaling.com
Option Strict Off
Imports System
Imports NXOpen
Module Module1
Sub Main()
End Sub
End Function
End Module
Try
End Try
Try
End Try
Try
End Try
Me.Close()
End Sub
Me.Close()
End Sub
Me.Text = myPart
Try
TextBox1.Text = ""
End Try
Try
TextBox2.Text = ""
End Try
Try
TextBox3.Text = ""
End Try
End Sub
End Class
Try
End If
Finally
End Try
End Sub
Me.SuspendLayout()
'TableLayoutPanel1
'OK_Button
'Cancel_Button
'Label1
'TextBox1
'TextBox2
'Label2
'TextBox3
'Label3
'Dialog1
Me.Name = "Dialog1"
Me.Text = "Dialog1"
Me.PerformLayout()
End Sub
End Class
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
www.studiotreccani.com
RE: attribute windows . need another row
CODE
www.nxjournaling.com
