Catia progressive die kinematics
RE: Catia progressive die kinematics
What??? no Kinematics ?!??
How did you do that?????
Eric N.
Exactly. No kinematics. See the environment in the video.
It was made with macros and some parametric models. It has the real curve of mechanical press. This was the first step that I have made, but my aim is to simulate transfer dies, with the transfer arms.
macros and parametric models???? Why did you use macro / parametric model ?
to move stuff around I use DMU Nav with tracks and sequence... very easy / rapid. It would take 2 minutes to do the video you made, a bit more if you want to control camera by track also; but still I guess it would be faster than parametric model & script.
Eric N.
