Python: How to select all instances at once?
Hi everyone,
Using Python, I'm trying to select the faces of all instances with getByBoundingBox:
CODE --> Python
faces = a.rootAssembly.instances['Part-1'].faces.getByBoundingBox(...)+        a.rootAssembly.instances['Part-2'].faces.getByBoundingBox(...)+        a.rootAssembly.instances['Part-3'].faces.getByBoundingBox(...)+        ...
This is very tedious for many instances. Unfortunately, rootAssembly doesn't have the attribute faces, so I can't use
CODE --> Python
faces = a.rootAssembly.faces.getByBoundingBox(...)
Is there an alternative way to select all faces with a bounding box?
Thanks very much!
RE: Python: How to select all instances at once?
Just collect all faces with two simple for-loops. The first over all instances and the second over all faces of each instance.
Thanks very much for your response. When I try to do that, I get an error saying "TypeError: 'Repository' object is not iterable"
My code is:
CODE
edges1 = []
for i in a.rootAssembly.instances:
    edges1.append(i.edges.getByBoundingBox(-1,-1,-1,1,1,1))]
_____________________________________________________________________________________
Edit:
I think I found the solution (maybe there's a simpler one?):
CODE
edges1 = []
for i in a.rootAssembly.instances.keys():
    edges1.append(a.rootAssembly.instances[i].edges.getByBoundingBox(-1,-1,-1,1,1,1))]
Edit2:
I have to do the second iteration, as you mentioned, as well:
CODE
edges1 = []
    for ii in a.rootAssembly.instances[i].edges.getByBoundingBox(-1,-1,-1,1,1,1):
        edges1.append(ii)
Edit3:
I give up.. the above works for the edges, but not for faces. When I do it with faces, i get the error "TypeError: faces; found tuple, expecting GeomSequence"
Any help is appreciated, please.
That below is what I've ment. With these simple loops you cycle over all faces and can do whatever you like with it.
CODE -->
a = mdb.models['Model-1'].rootAssembly
for iname in a.instances.keys():
    for xface in a.instances[iname].faces:
        print iname, xface.index
This is in the Assembly module , what if I want to select the faces of a part in the part module with getByBoundingBox ??
