Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...I have answered some questions and have gotten answers for my questions. Anywhere you can do this on one page helps tremendously..."
Geography
Tatonka (Mechanical)
31 Dec 02 9:30
I'm examining a military specification for a servo valve assembly and there are a few requirements/specifications that don't make a whole lot of sense to me...
The spec states that the "valve bias pressure at hydraulic null shall be 5 to 50% of supply pressure."  The valve is a hydraulic pilot vlave (where the pilots are supplied by a servovalve).  The test procedure reads that the control ports should be sealed and the servo valve adjusted so that "the blocked control port differential pressure is zero" and "the common control port pressure...shall be 415 +/- 340 psig."  Does this mean that the servo valve is actuated appropriately to equalize the control port pressures and this common pressure should be within these specifications?  If so, what does this tell us about the valve's operation (why is this specification necessary)?
The specification also lists a required hydraulic stiffness of 8,000psid/cubic inch of fluid added @ 750 +/- 25 psi.  I did some research and could not find any listed hydraulic stiffnesses with these units: they all had units of lbf/in.  Are these equivalent units?
M Woelfersheim
tannguyen (Military)
7 Jan 03 9:46
psi/cubic inch is lbf/in.
Breaking the units down:
[lbf][in^2]
[in^3]
don't ask me what the "d" is...dynamic psi???
7 Jan 03 10:15
I tried working out the units, but it looks like this, doesn't it?
      lbf
psi = ----
      in^2
            lbf     1      lbf
psi/in^3 =  ---- x ---- = ----
            in^2   in^3   in^5
Is this a specification on the elasticity of the system (tubing, etc)?  If you add a cubic inch of fluid, the pressure must increase at least 8,000 psi?
7 Jan 03 10:20
sorry...didn't preview...
         lbf
psi = ----
         in^2
                 lbf      1       lbf
                 in^2  in^3  in^5
IRstuff (Aerospace)
7 Jan 03 11:36
Did you find the spec number?
TTFN
7 Jan 03 11:45
sorry it took me so long to get back to you...spec number is 10237-3102 for part 12283102 - Servomechanism, Elevation.
IRstuff (Aerospace)
7 Jan 03 12:41
Sorry, I don't have access to that document.
psid is differential pressure, of course.
Sorry can't offer more help.  I tried to find some related mil-specs, but there didn't seem to be any that I could find that were directly applicable.
TTFN
7 Jan 03 12:52
The only way I can access the spec is through the "Viewer" program on an Army terminal.  It has images of each page and you have to print them individually...great use of time, eh?  our tax dollars hard at work...
10 Jan 03 16:11
sorry I screwed up.
It's a really old (1978) spec that is inactive
estimator79 (Civil/Environme)
13 Jan 03 11:30
Ask the contracting officer for an explanation.
13 Jan 03 11:44
the company i work for does contract engineering work through GSA...we don't supply parts, so we don't have a contracting officer...i'll try to find one, though...
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Military engineering other topics Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=431
DESCRIPTION: Military engineering other topics technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
