Sloping Roof Deck - Tilt Beams?
On a flat roof, with slope 1/4" per foot or less, if the roof deck flutes are parallel to the span, and the supporting beams are perpendicular to this, is it customary to install the beams plumb, or slightly out of plumb so that the slope of the beam top flange matches the roof deck slope? What is the slope limit when supporting beams must be installed out of plumb to match the slope and the slope can no longer be neglected?
RE: Sloping Roof Deck - Tilt Beams?
Can you post a sketch of your situation just so there isn't confusion. Most of the time any beams running parallel to the flutes are separated from the deck via joist seats.
BA
If it's the situation that I'm thinking of, I'll usually rotate the beams.
Not much. 1:24 on a required 1.5" bearing surface or 1/16" max. See the attached document from SDI.
Metal roof deck flutes must be parallel to the supporting element, whether the supporting element is a purlin, open-web-steel-joist or a beam, and thus, the supporting element must be perpendicular.
What are the supporting elements? If it's just a beam, the adjacent support cannot be very far from it. If it IS just a beam, you may need to shop weld a 1/4:12 sheet stock or install a sloping fire-resistant wood element, all depending on your construction type, code rules, etc...
There are too many unknowns. A sketch would be nice.
Mike McCann, PE, SE (WA)
