NX - The 50-50-90 rule?
* Caution, this is pure whining - but want to know what other users think. Can Siemens put more effort into intuitiveness?
The 50-50-90% rule with NX is that when an operation is binary in nature (50-50%) NX will 90% of the time pick the option I don't want. Does anyone else see this?
One example: Many times making a counterbore hole, NX picks the vector away from material. How do you put a hole into air? Until I explicitly choose a vector (obviously going into the material) it won't put the hole in.
Many operations in NX work this way. We keep thinking this will get better, but we're on NX 9 and it drives users crazy.
Thoughts?
RE: NX - The 50-50-90 rule?
I can honestly not remember a single time it picked the wrong direction for a hole feature. I'm on NX8 for now until we get NX10 deployed.
It's ok to whine sometimes.
But, In the case of "Hole" features, there must be something wrong with either how you do this , or your settings.
Because :
All solid models consist of "surfaces" and what makes the surfaces a "solid body" is that there is a scheme which "knows" all about the surfaces, the edges, the vertices, which face is next to which etc etc,
AND, ALL face normal's points consistently OUT. - This way the system knows which side of a face is the inside of the body.
When somebody wrote the code for the Hole feature , He/She knew that if you pick a point ON a face, the default drilling direction is the opposite of the face normal.
If that point isn't on a face, then it might be 50/50, and as you say 90% wrong...
Do your points "sit ON the face" such that the point/the pick will return the specific face to NX ?
Tomas
