Corrosion standards
Corrosion standards
Dear,
Is there any standards about corrosion which can consider material selection ( chemical factors ).
For example which is the right standards to know it is recommended to use galvanised steel than the carbon steel ?
Regards.
Regards.
RE: Corrosion standards
Lacking that, you should look at a corrosion chart.
http://www.engineeringtoolbox.com/metal-corrosion-...
