Ventilation in a crawl space
Some replies in my other post got me thinking about ventilation in a crawl space and freezing issues. By code you are supposed to have ventilation in a crawl space. How do you prevent the plumbing from freezing if there are vents in the crawl space? Are the vents just closed/blocked off during the winter?
RE: Ventilation in a crawl space
Plus you have the contribution in the heat from the structure above, if it is heated.
Mike McCann, PE, SE (WA)
From Lstiburek's US Dept of Energy white paper:
Unvented Crawlspaces Code Adoption
Heated and vented is common in areas where freezing is a concern.
I think you meant heated and UNVENTED. That is the only way I will do crawlspaces. Cold floors are impossible to live with and insulated floors over cold spaces are always cold. Treat the crawlspace like a basement & everything is better: no moisture problems, no deteriorating joists, no freezing plumbing, easy to run HVAC in a conditioned space, the floor is warm. etc. etc.
