Matching billet material properties in casting
Hello all,
I am working on a project and having a bugger of a time finding a foundry that can help me match the material properties I am currently getting in a billet part. We are using 4340 and a custom heat treat recipe to get the following properties. Is there any way that these can be matched in a casting? Thanks in advance.
- Yield 925MPa
- Ultimate 1080-1230 MPa
- Elongation 11%
- Charpy >35J @ -20C
RE: Matching billet material properties in casting
There are a few guys here that are much better with cast steels than I am.
Here's a couple technical references for alloy steel castings:
http://everyspec.com/MIL-SPECS/MIL-SPECS-MIL-S/dow...
http://www.ruger.com/casting/T-Steel.html
Castings are prone to contain several heterogeneous defects like inclusions, dissolved gases, segregation, coarse grains etc.
The foundry can deliver your mechanical properties in the castings, by selecting a suitable casting alloy.
This problem is faced while reengineering from a forged part to a cast one, without understanding the limitations of cast process.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
I have recorded the Quote from Mahatma Gandhi [listed within my large file of quotes], thus...
Speak your mind. Even if you are a minority of one, the truth is still the truth.” --Mahatma Gandhi
Regards, Wil Taylor
o Trust - But Verify!
o We believe to be true what we prefer to be true.
o For those who believe, no proof is required; for those who cannot believe, no proof is possible.
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can break them like an artist. [Picasso]
