Should I use a Special CN or add a pond for modeling a stone area?
I have a subcatchment described in the attached photo.
The subcatchmet has a roof with five disconnected roof drains that spill onto stone (open graded ASTM #2 stone with no fines) areas. Each stone area has a catch basin. The catch basins are part of a longitudinal network which outfalls into an existing storm water pond. The stone depth is approximately 12". Assuming a porosity of the stone to be 0.54 I could assign a special CN value of 61 for the stone.
S=1000⁄(CN-10)
Where: S = depth in inches
If S is calculated as the available voids in the ASTM #2 stone, the CN can be estimated by rearranging the equation as:
CN=1000⁄(S+10)
CN=1000⁄(0.54*12"+10) = 61
I would like to take advantage of exfiltration (1.02 in/hour) beneath the stone. Should I use a CN value of 96 for the stone, use a pond depth of one foot, the surface area of the stone, the volume of the voids as my storage volume, and 1.02 in/hour for exifiltration. I'm afraid I'll be overestimating my storage if I use a value of 61 while incorporating the storage of the stone into a exfiltrating pond. If I use a pond for exfiltration before the flow enters the catch basins what CN value should I assign the stone, 96 or 61? The stone areas I would like to incorporate storage are about 0.1 acres in size each.
What is the best way to account for the storage and exfiltration the stone areas provide?
Thank you,
S=1000⁄(CN-10)
CN=1000⁄(S+10)
Thank you,
RE: Should I use a Special CN or add a pond for modeling a stone area?
Peter Smart
HydroCAD Software
www.hydrocad.net
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
