Plate deflection and stress formula
I am looking for a formula to determine max deflection and stress of a plate (round or square) that is simply supported in the center (round support) and a uniform load over the whole surface. Can anyone point me to a good example?
Thanks.
RE: Plate deflection and stress formula
roark ?
For a circular plate you can obtain a solution by superimposing, on a simply supported plate, a uniform load and a point load of opposite direction and same resultant.
For a square plate the same can be done, but you need the solution for a plate supported at the corners only, that you can find here and here.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Thanks, metengr's link was close, but there was a better match to my situation Link
Roark's Formulas for Stress and Strain would work as well for just about any situation, adding to my collection.
No.
That web page assumes a ring support (NOT a simple single support at the center of a round plate as in your original statement).
After entering a round 10 unit diameter plate with a 2 mm thickness, it told me the edges of the plate deflected more than the original plate thickness under a 100 load.
Not sure I'd trust it.
