Identifying the phases in 300M steel
A small sample of 300M steel was held at 650C for 30 minutes and then quenched. I have included 2 pictures of the microstructure, one in the centre and one at the edge of the sample, and was hoping someone could help me identify them. I believe it is a bainitic structure with some martensite but not 100% sure.
Pictures:
http://files.engineering.com/getfile.aspx?folder=4...
http://files.engineering.com/getfile.aspx?folder=f...
Pictures:
RE: Identifying the phases in 300M steel
Maui
Kilian
Kilian
1. RE the 300M steel sample...
Did it come to You with material certifications for chemistry, temper and mechanical test data??
IF so, what exact material specification was Your 300M sample made per?
Did You characterize/verify the sample's alloy/temper/chemistry independently before testing?
What exact heat treatment specification did You accomplish the HT per?
2. May find the following SAE aerospace documents interesting.
SAE AIR4498 Aus-Bay Quenching of 300M Steel
SAE ARP1110 Minimizing Stress Corrosion Cracking in Wrought Forms of Steels and Corrosion Resistant Steels and Alloys
SAE ARP1631 Manufacturing Sequence for Fabrication of High-Strength Steel Parts 300M or 4340 Modified Low-Alloy Steels 270,000 psi (1860 MPa) Tensile Strength and Higher
SAE AMS2759/2 Heat Treatment of Low-Alloy Steel Parts Minimum Tensile Strength 220 ksi (1517 MPa) and Higher
SAE AMS2759/9 Hydrogen Embrittlement Relief (Baking) of Steel Parts
SAE AMS2759/11 Stress Relief of Steel Parts
AMS6417 Steel, Bars, Forgings, and Tubing - 1.6Si - 0.82Cr - 1.8Ni - 0.40Mo - 0.08V (0.38 - 0.43C) - Consumable Electrode Vacuum Remelted (Composition similar to UNS K44220)
AMS6419 Steel, Bars, Forgings, and Tubing - 1.6Si - 0.82Cr - 1.8Ni - 0.40Mo - 0.08V (0.40 - 0.45C) - Consumable Electrode Vacuum Remelted (Composition similar to UNS K44220)
AMS6257 Steel Bars, Forgings, and Tubing 1.6Si - 0.82Cr - 1.8Ni - 0.40Mo - 0.08V (0.40 - 0.44C) Consumable Electrode Vacuum Remelted Normalized and Tempered - UNS K44220
Regards, Wil Taylor
o Trust - But Verify!
o We believe to be true what we prefer to be true.
o For those who believe, no proof is required; for those who cannot believe, no proof is possible.
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can break them like an artist. [Picasso]
