How to change default colors for features
Whenever I create a draft feature, it makes the surfaces I drafted colored blue.
Can someone please tell me where I can change this default behavior?
TIA!
TIA!
UGNX 9.0.2.5 MP1 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
RE: How to change default colors for features
i have never heard of this problem before.
( it sounds like a quite nice feature to show what faces have been drafted/ tapered)
I wonder if this could be caused by some special environment variable ?
I would open the NX logfile and search for "draft" or "taper" ( taper was the old name for draft) "mold" ( maybe mold wizard has something to do with this )
Tomas
The files I create, the draft command does not change the color of the faces I draft.
Another designer worked on the files and save as a new revision. She does not know why it happens on her machine.
If I create a new draft on a file she worked on, it does not change the color of the faces.
My main issue is that when I try to change the color of the whole body, it would give me a warning;
"You have selected faces that are automatically assigned the color of the features that created them. When model updates, your color changes will be lost..."
And when the part regenerates, the color of the drafted surfaces reverts back to blue.
I have been trying to find where in customer defaults or preferences this is but no luck.
www.nxjournaling.com
Thanks!
