Problem with static analysis for composite beam
Hi everyone,
I'm having problem when modeling composite beam with concrete slab with static analysis. This analysis involve with the composite beam and concrete slab were exposed to fires. I keep getting this error 'THE MATERIAL OPTIONS *CAP PLASTICITY, *CAST IRON PLASTICITY, *CLAY PLASTICITY, *CONCRETE, *CONCRETE DAMAGED PLASTICITY, *DRUCKER PRAGER, *FOAM, *CRUSHABLE FOAM, *MOHR COULOMB, *JOINTED MATERIAL AND *PLASTIC ARE MUTUALLY EXCLUSIVE'. Can someone help me to solve this problem?
I has define material properties of elastic, density, drucker prager yield criterion including hardening and also concrete damaged plasticity in which I specify plasticity, compressive behavior and tensile behavior. I really appreciate if someone could help me.
Thanks again
RE: Problem with static analysis for composite beam
I think the message is pretty clear: You've used plasticity options, that can't be used together.
