ESD Forced/ ESD MOS
ESD Forced/ ESD MOS
ESD Forced/ ESD MOS
Good day
I am working in a refinery as a process engineer, I have encountered the terms above but I couldn't understand them well.
what do those terms mean?
thank you
RE: ESD Forced/ ESD MOS
ESD forced might be that the system can force the reset or opening of an ESD valve.
Sometimes happens when you need say <5bar across the valve to open but even with a bypass fully open you can't get the differential low enough, then you would / could force the ESD valve to open.
The last one I found via google in about 15 seconds - http://www.infineon.com/dgdl/an-986.pdf?fileId=554... seems to refer to an ESD test of a circuit.
ESD MOS = ESD Maintenance Override Switch.
ESD MOS is a built-in switch provided in the DCS to enable maintenance of trip transmitters/system so as to avoid inadvertent trip of the plant/unit. Normally the overridden trips gets back to normal after a period of time say 8 hours.
John
