Hello I am looking for some guid
Hello
I am looking for some guidance concerning aircraft bonding-ground return for a large motor. (Note: aircraft electrical systems use the aluminum structure as the negative-ground return for all electrical components) I am working on a twin engine, turbo-prop that is undergoing an airframe overhaul. This aircraft has an aluminum fuselage with the engine mounts made out of welded steel tubing. All the structural components in the engine mount to airframe interface are of course heavily primed/painted. Each engine has a 28VDC starter/generator. Additionally, a main battery and various other electrical components are in each nacelle area. I need to determine what materials, (flexible braided straps, solid-flat plated copper straps ??) and what sizes are required. The generator output is rated @ 200A and I believe the starter pulls in the area of  400 to 600 amps (short duration). Also where do I need to stop with the bonding (large current ground return)? Does the wing (1 piece) to fuselage attach point require attention too?
Thanks for the help
J. Stolp
RE: Hello I am looking for some guid
jstolp
Check the bonding and grounding requirements for aircraft
in the following:
Airframe handbook asa-ac65-15a
or
see the following web site
av-info.faa/dst/43-13/ch11-15.doc
nickbo
jstolp
PS Check that specific aircraft and engines maintenance manuals
nickbo
Must not be military.  All military EMI design guides forbid running current's through the chassis.
I'm surprised this is done elsewhere, as this makes the entire aircraft a flying antenna.
TTFN
Suggestion: An adherence to military or commercial standards, specifications and handbooks is normally followed.
Small encore: Reference:
MIL-C-83413A(1) SUP 1 NOT 1  Active  5935  CONNECTORS AND ASSEMBLIES, ELECTRICAL, AIRCRAFT GROUNDING, GENERAL SPECIFICATION FOR
(Specification dated 23 March 1984)
