catproduct and catpart, what is the difference
In very simple terms, what is the difference between a CatProduct and a CatPart?
If I am designing an internal combustion engine, then is the engine the CatProduct and the piston, crankshaft etc are they CatParts?
RE: catproduct and catpart, what is the difference
CATProduct = Assembly
CATPart = Component within the assembly
Yes. The combustion engine is the CATProduct (i.e. Assembly) and all of the CATParts within it are the components that make up the engine assembly.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
why do you have to do this with catia? It seems you did not get training on the software.
Eric N.
