Double pipe heat exchanger
I am to review the data sheet of a double pipe heat exchanger to be used in a Wet air oxidation process in a waste water treatment plant for spent caustic service. Alloy 600 material has been suggested by the contractor for this service. Temperature of around 140 deg C and air is injected upstream of this exchanger at a pressure of 33 barg.
Can anyone suggest me the factors to be considered before providing green signal to the contractor to go ahead?
I am new to this equipment and thanks in advance for your valuable information
