Engine Overheating Issue --- thread71-157210
I found this forum and looks like experience the same problem as in thread71-157210: Water Pump Pulley Sizes for Early Ford Engines
The last msg from AllorNothing ends and I wanted to know was it ever resolved ?
(ford big block 460)
anyone ?
thanks
Rob
anyone ?
thanks
Rob
RE: Engine Overheating Issue --- thread71-157210
... whereas one would expect the fan to be running within the shroud, not behind it,
and the persistent symptoms reported suggest insufficient or marginal airflow at idle, duh.
Mike Halloran
Pembroke Pines, FL, USA
No problem I guess... I suppose the fan will simply machine away the required clearance... [wink]
