Bystronic BTL2800
Bystronic BTL2800
Hi everyone,
We have bought a used Bystronic Bystar with btl2800 resonator.
The machine is moving in xyz and it seems like everything else is in working condition after some repairs. We have not yet started the resonator.
There was a water leak in one of the copper cooling coils. That has been fixed.
The vacuum pump is running. Also the turbine is running. The chiller is running.
The resonator has been cleaned and o-rings replaced. One of the ceramics was replaced. New optics.
Is there anything we should check before turning on the high voltage?
Does anyone know the password for the keb inverter? I would like to document the parameters.
