Solid edge st2 64-Bit on win 7 & win 8 64-Bit OS How should i install it
Dear Expert ,
I am in very badly intention plz help me out from this prob..
we all are using solid edge st2 32-Bit, But on New laptops it come with 64 bit OS,
HOW SHOULD I GET THE SOLID EDGE ST2 64-bIT ON WIN 7 & WIN 8 64 -bIT
RE: Solid edge st2 64-Bit on win 7 & win 8 64-Bit OS How should i install it
ST2 is *not* supported on Windows 8. ST6 was the first version supported with Windows 8.
You can install 32-bit Solid Edge on 64-bit operating systems. It is not necessary to install 64-bit Solid Edge onto 64-bit OS. 32-bit Solid Edge will work without issue on 64-bit Windows.
The ST2 64-bit Solid Edge can be downloaded from the GTAC file server -- if you still have active Solid Edge maintenance. If you no longer have active Solid Edge there there is no official way for you to download the 64-bit version.
http://about.me/davidmerritt
