free or constrained state
RE: free or constrained state
loka23,
When does the diameter need to be 11.35+/00.015, when it is free, or when it is constrained?
JHG
After machining the slot the inside diameter Dia 11.35+/-0,015 should be constrained.
loka23,
That is not what I meant. When you use this thing, what happens to the diameter?
If this thing is slid over an Ø11.6 pin and retained by friction, the Ø11.35±0.015 should be measured in the free state. You could specify the force required to slide this thing over a test pin, although I doubt the machine shop would like you.
Note that I said "If...".
JHG
