ASME VIII-1 Fig. UCS-66 note 3(b)
Hi everyone:
I have a question regarding ASME VIII-1 Fig. UCS-66 note 3(b), for impact test exemption curves.
Subject note reads "all materials listed in 2(a) and 2(c) for curve B if produced to fine grain practice and normalized, normalized and tempered, or liquid quenched and tempered as permitted in the material especification, and not listed in curve D below".
The bove provides 3 options to change a curve B material to curve C, since I'm not a mettalurgist my question is whether or not the "normalized and tempered" and the "liquid quenched and tempered" options both require also the fine grain practice on a given material for being able to change it from curve B to curve C.
All comments/guidance are welcome.
RE: ASME VIII-1 Fig. UCS-66 note 3(b)
The material just needs to be 1 of the following 3 conditions:
1. Fine Grain Practice and Normalized
2. Normalized and Tempered
3. Liquid Quenched and Tempered
If you go with either option 2 or 3, the material does not have to be fine grain practice.
Hope that helps!
