Cast steel Ground Engagement Tool failure after hardfacing
We make these cast steel tips for dragline buckets. Several failed recently, failure rate much higher than usual.
We had a batch of these tips hardfaced on top, front, side and bottom faces. Hardfacing didn't cover full face, just few ~20 mm wide weld lays of hardfacing metal.
All the failures have been in this batch.
Material is cast steel with Carbon equivalent of 0.7, typical hardness 400-450 BHN (43-47 HRC), typical yield strength around 750 MPa (108 ksi)
Here are some photos of the failed part:
Here's a rendering of the part with hardfacing:
Can anyone please shed some light on possible cause & remedy?
I don't have any info on how the hardfacing was done, if any pre-heat or PWHT applied.
I was thinking this overwhelmingly brittle fracture was because the part was cooled too quickly, making it too hard to the application.
Not sure if pre-heat will help, part is too small to hold heat & remain in high enough temperature may be?
I was more inclined to some form of PWHT after hardfacing, or at least put it in furnace for slow cooling.
Thanks.
Thanks.
RE: Cast steel Ground Engagement Tool failure after hardfacing
We used to hard face some parts, they were pre-heated, then pulled and placed on insulation while the overlay was being applied, then put into a box furnace an temper temperature. When the batch was done the furnace was shut off and allowed to cool.
For fun, before sending the parts off to the metallurgical failure analyst, I'd try drilling a few shallow hole in the surfaces near the cracks with a sharp cobalt 1/4 inch drill at slow speed with lubricant. I'd be looking for the drill to form short curly chips, and not dust
As suggested by metengr, get the complete analysis, before any inference can be made.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
1. Coarse grain structure - very likely your casting / heat treatment process needs closer attention.
2. Also suggested a WPS/PQR for hardfacing build - up welding.
3. And "yes", root cause analysis is highly recommended to mitigate all possible combined side effects for both casting; heat treatment and hardfacing processes.
IBFmining1.
je suis charlie
