How to design for reinforced concrete saddle with footings?
We have an existing high pressure pipe that will be in the subgrade layer under the select fill material of MSE wall. I'm looking to protect this pipe with concrete saddle and transfer the load to the footings. Any suggestion how to design this concrete cover? thickness and reinforcement?
RE: How to design for reinforced concrete saddle with footings?
BA
We can’t see what you are looking at from here. Imagine the hundreds of sketches which would fit the description you have given. And, they would all be correct, but not what you are dealing with.
That's the best I can make out from your current description.
