1 1/2" Hose Valves
1 1/2" Hose Valves
Got a quick question, I have read this somewhere but cant find it again, arggg. We have a situation where a single 1 1/2" hose valve is against a fire rated wall. The owner wants another hose valve and the other side of the wall, and I believe you can connect to the existing piping and supply the additional hose valve in that situation, but I cannot find where is states that.
Thanks for the help.
RE: 1 1/2" Hose Valves
Is this hose valve provided as a 13 or 14 application?
R/
Matt
Eric Hendrix, SET
NICET Certified
Design Manager
And it is not also a 2 1/2 inch connection ??
Might just talk to the ahj to see if they still require it.
What type of occupancy is this??
Like I stated above I think you can add another hose valve to the existing line on the other side of the wall, but only in that situation.
Eric Hendrix, SET
NICET Certified
Design Manager
Chemical storage ??
