NX9 Assembly part quantities on individual detail dwg's possible?
I never include a part count on a dwg. detail because it's one less thing I can key in wrong.
But it sure would be nice if it were possible to get that count out of the top level ass'y an onto the detail. Seems like a stretch tho.
Anyone have a method???
TIA
Dave
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: NX9 Assembly part quantities on individual detail dwg's possible?
do i understand you correctly, You want the number/quantity of say "venturi-brackets" that are needed in assembly xyz to be noted on the drawing "venturi-bracket-dwg1" ?
( and not noted in the BOM on the drawing "xyz-dwg1" )
Or is it "detail views" we are talking about ?
Tomas
Close!
Yes, I want the number of "venturi brackets in top level ass'y "xyz" to appear in, top level ass'y parts list in "xyz_dwg1" & anywhere on "venturi-bracket_dwg1" (No "detail views")
The shop is always having to go back to a master spreadsheet or assembly drawing to re-connect with how many they are supposed to make. Rather than just having it on the detail they carry around the shop.
I don't put it on the details manually to avoid a whole new level of error prone management on large projects. Everything we build is "one off" so we only have one chance to get things right and make money.
Dave
NX9, Win 7 Pro SP1
