Journal to move assembly components beginning with a certain letter to a layer
I've been trying to create a journal to send all components in an assembly which begin with a certain letter (in this case 'F') to a layer. I've tried loads of bits of code from other similar threads online, but cant get any of them to work. I think the problem might be that I am using the wrong object type (if that's the right term? I mean such as 'as component' or 'as ComponentAssembly'). I was trying to add the components that begin with F to an array, which i would then process to move the layer.
The code below is one not-working version of what i have managed to do so far. I tried using parts of the code which is created when i recorded a journal of moving a component to a layer, but that didn't work either. The commented out section of the code is what i used to see if the code is at least finding any components beginning with the letter F, and it seems to be able to do that - Its just the moving to a layer part I'm stuck with.
I hope someone will be able to point me in the right direction.
Thanks in advance.
Thanks in advance.
CODE -->
Option Strict Off
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Assemblies
Imports NXOpenUI
Module NXJournal
Sub Main()
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim dispPart As NXOpen.Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
lw.SelectDevice(ListingWindow.DeviceType.Window, "")
lw.Open()
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
Dim Fixings As ArrayList = New ArrayList
Dim Part(0) As NXOpen.DisplayableObject
If Not IsNothing(c.RootComponent) Then
ReportComponentChildren(c.RootComponent, Fixings, Part)
'Dim fixing As String
'For Each fixing In fixings
' lw.writeline(fixing)
'Next
Else
lw.WriteLine("Part has no components")
End If
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
End Sub
Sub reportComponentChildren(ByVal comp As Component, ByRef Fixings As arraylist, ByVal Part() As DisplayableObject)
For Each child As component In comp.GetChildren()
If child.DisplayName.ToUpper Like "F*" Then
part(0) = child
workPart.Layers.MoveDisplayableObjects(199, part)
'Fixings.Add(child.DisplayName.ToUpper)
End If
reportComponentChildren(child, Fixings, part)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
RE: Journal to move assembly components beginning with a certain letter to a layer
I managed to fix this myself - It's messy but it does the job! I hadn't passed the 'workpart' to the 'reportComponentChildren' sub.
If anyone has any general tips for cleaning up this code, I'd be happy to hear them.
CODE -->
Option Strict Off Imports System Imports System.Collections Imports NXOpen Imports NXOpen.UF Imports NXOpen.Utilities Imports NXOpen.Assemblies Imports NXOpenUI Module NXJournal Sub Main() Dim theSession As NXOpen.Session = NXOpen.Session.GetSession() Dim workPart As NXOpen.Part = theSession.Parts.Work Dim dispPart As NXOpen.Part = theSession.Parts.Display Dim lw As ListingWindow = theSession.ListingWindow lw.SelectDevice(ListingWindow.DeviceType.Window, "") lw.Open() Try Dim c As ComponentAssembly = dispPart.ComponentAssembly Dim Fixings As ArrayList = New ArrayList Dim Part(0) As NXOpen.DisplayableObject If Not IsNothing(c.RootComponent) Then ReportComponentChildren(c.RootComponent, Fixings, Part, workpart) 'Dim fixing As String 'For Each fixing In fixings ' lw.writeline(fixing) 'Next Else lw.WriteLine("Part has no components") End If Catch e As Exception theSession.ListingWindow.WriteLine("Failed: " & e.ToString) End Try End Sub Sub reportComponentChildren(ByVal comp As Component, ByRef Fixings As arraylist, ByVal Part() As DisplayableObject, ByVal workpart As NXOpen.part) For Each child As component In comp.GetChildren() If child.DisplayName.ToUpper Like "F*" Then part(0) = child workPart.Layers.MoveDisplayableObjects(199, part) 'Fixings.Add(child.DisplayName.ToUpper) End If reportComponentChildren(child, Fixings, part, workpart) Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function End Module
