Question about example from Blodgett
Hello everyone,
I am looking at an example from Blodgett where the resultant shear force on a weld group is found. The weld group is loaded with both an in plane and out of plane load at an eccentricity. The example is shown in the attachment.
What I don't understand about the example is why there is no direct shear force on the weld due to the 200 lb force. I think a direct shear of (200 lb)/(3 in + 4 in) should be put on the weld group. Am I missing something?
RE: Question about example from Blodgett
I think you are correct....there is additional shear on the weld overall. The moment from the horizontal force (200 lbs.) isn't a pure moment acting on the group but a force causing a moment...just like the vertical 300 lb. force.
JAE,
I agree with you. The only logic I could come up with is Blodgett is taking the direction of the vector into account. Although, when designing a weld I have never taken the direction of the vectors into account. I just make everything positive and find the resultant force.
It feels like blasphemy to say so but, I agree, it appears that the example is in error.
Quote (Perception)
In figure 26, I think that the 211 lb force is actually pointing the wrong way. Pointed the right way, I believe that it would indeed be additive to the direct horizontal shear.
