Large Truss - Extremely large stresses and deflections
Hi there,
I'm trying to model a large truss (~180m span) with pin supports and cantilever ends however I am getting huge stresses and deflections in my results output under Gravity loading.
All units have been checked and are appropriate (m, N, kg, s, Pa, J, kg/m3)
In this model, I have imported the whole truss from AutoCAD as a single part, although I am also able to sub in parts separately using the Layer feature in AutoCAD. The problem I have with importing separate layers is that the deformed shape seems to "fall apart" (massive deflections, too large to even display shape). I assume this is some sort of problem with the interaction at the nodes for a multi-part model. Please tell me if importing the whole part as a single part is wrong.
I have attached the .cae file if any of you can give it a quick look over. This is a simplified model of the supertruss at the NRG/Reliant Stadium in Texas.
http://files.engineering.com/getfile.aspx?folder=d...
RE: Large Truss - Extremely large stresses and deflections
Check your Youngs Modulus again.
Thank you Mustaine3 for your continued help with my Abaqus queries, you have been of considerable help in my previous thread posts.
I have corrected the Youngs Modulus to 2e12 (200 GPa in Pa) - can't believe I made this error continuously! I seem to now have realistic output results, much appreciated!
