Changing Part color in an Assembly, Save to Part
Hi, is there anyway to save color changes applied to a part in an assembly to the part itself? The scenario this would be helpful is when I have a similar intricate part in an assembly and I want to selectively inherit all the various face colors by being able to pick on the other part faces one by one. I can't do that obviously when the part is 'Made Display Part'. Any help would be greatly appreciated. Thank you.
RE: Changing Part color in an Assembly, Save to Part
OBJECT DISPLAY
change filter selection face,body ecc..(don't select assembly)
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
www.studiotreccani.com
NX 7.5 64bit
Thanks!
But, you need not have selected the "component" to start with, you must select "solid body" or Face etc , else this option will be grey.
Tomas
www.nxjournaling.com
