Solid pump for plastic grinding.
I want to continuously transfer plastic grinding of size approx 5 mm into the base of a water collumn about 10 feet height and dia 5 feet continuously.I would be grateful if someone could guide me as to how this be accomplished.
RE: Solid pump for plastic grinding.
Could you do it pneumaticly?
You might do better in materials handling or like forum.
Even better, don't take the word of a random idiot on the Internet; talk to a pump manufacturer, supply them some samples of your plastic bits, and ask them to recommend a closed impeller large enough to pass your stuff, or an open impeller, a paper stock impeller, or even a trash pump impeller. Pumping bits of plastic in water is not new technology.
Mike Halloran
Pembroke Pines, FL, USA
Question: how do you ensure the plastic floating on top ends up in the pump inlet?
Mike Halloran
Your suggestion has merit, the problem will be finding the best submergence so as to entrain the plastic while not entraining excessive air putting the pump off prime.
https://www.bing.com/videos/search?q=how+to+pump+m...
this unit might be available with electric drive or capable of being modified.
A floating pump with one of the impellers which Mike suggested should work.Thanks a ton.
What is the output of your grinder? Is it already in water? Dry?
A water ejector pump might work for you:
https://www.google.com/search?q=water+ejector+pump...
- feed plastic to tank bottom with long auger
- feed plastic to tank top, and mix
Or have a small tank with a mixer, you submerge the plastic bits by mixing and pump from there.
Some sort of paddle mixer or agitator would seem to be a good idea
