Transition Truss with Dropped Top Chord
Has anyone ever seen a transition truss with a dropped top chord? If such a thing exists and you have a drawing or pictures please post.
A confused student is a good student.
Nathaniel P. Wilkerson, PE
www.medeek.com
RE: Transition Truss with Dropped Top Chord
What exactly are you referring to?
www.medeek.com
I've done a DTC one one side of such trusses. But not too often. DTC gables aren't common in this area.
www.medeek.com
www.medeek.com
I will bite and ask the question. Why is the top chord of the higher ridge in your last two examples dropped approximately 1 inch.
Jim
The perspective in this screenshot makes the heel webs look out of plumb, they are actually plumb.
www.medeek.com
www.medeek.com
1) Make the structural truss match the larger profile.
2) Drop the top chord and install the outlookers the whole way.
3) Build in some gable verts where you need 'em.
4) Maybe drop a web to the new interior bearing.
5) If you're a P.Eng/hardass, give some thought to how you transfer diaphragm shear across the transition.
www.medeek.com
The left most gable truss (grid A), with the vert. nailers in place of diag. members should have the top chord dropped 3.5" measured perpendicular to the slope, so that standing 2x4 outriggers can span over it, from the first interior truss top chord out to the sub-rake 2x. The normal top chord tails are cutoff at the outside of the top pls. and the bot. chord end there too. Then a short standing 2x4 tail is plated to the top of the normal top chord, in the same truss plane, with several feet of back span, up to the first outrigger. The framing in the lower corner btwn. the sub-rake and the eave sub- fascia, is just stick framed fill-in. You can nail those outrigger ladders together on the ground if you wish, with the sub-rake, and some blocking over the gable truss and btwn. some of the (or all of the) outriggers, and install the whole half of the rake at one lift.
Then there are a group of std. king post trusses moving to the right and upward toward grid B. This same truss is used over grid B, and you have the truss guys build a short vert. gable wall on top of it, with vert. nailer studs and the top chord held down 3.5", and the other normal top chord extended to meet. Again, the outriggers are about 4' long and canti. over this transition truss and back to the next first interior std. truss. The outriggers get end nailed at the first interior truss top chord, and you might add light joist hangers up-side-down at these joints. Same thing toward and at grid C. Depending on what the truss guys want for these transition trusses, you might stick frame the funny dropped vert. gable walls on top of the std. trusses.
The gable trusses in the cathedral/vaulted ceiling area are done about as you show them, with a 3.5" dropped top chord. The builder will bitch, but it’s probably best that these gable walls be framed full height to the under side of the truss, the bracing area and ceiling diaphragm. The upper most, right most end, of the right gable truss, out over grid F, should have a standing 2x4 on top of the normal top chord. It will have a longer back span going back toward the ridge btwn. grids E & F. That’s kinda a nasty transition btwn. those two vaulted ceiling areas. You gotta study that a little more, as to interior ceiling planes and ridge lines, etc. I’d either stick frame a sloped ledger to the main gable truss from the main room, or put a std. small scissors truss right against the main gable truss.
Your sketches at 20MAR16, 18:18 & 19:30 look like real abortions, you better study them a little more. What’s with the out sloping (not plumb) raised heels? Making two vaulted ceilings of different spans or pitches meet end to end is almost always difficult. Draw cross sections through the two rooms at that meeting wall, and then you have to study how to make it work. What ceiling planes match and differ and which wall face will show the vert. transition, and then how to frame the roof in that immediate area.
By the way you can download any of these SketchUp models if you want to rotate them in 3D or zoom in to a particular spot:
https://3dwarehouse.sketchup.com/by/medeek
www.medeek.com
______________
MAP
______________
MAP
