Maximum gate voltage on a triac
I have a TIC226D triac. I see maximum gate current on it's datasheet (50mA, if I'm not mistaken), but I need to know the maximum allowed tension.
Is there a way ?
Is there a way ?
RE: Maximum gate voltage on a triac
But, since there is a current limit, just keep the gate current at a level safely below that limit. And, please, be aware that there are different specs for operation in the different quadrants with 3rd quadrant being the most demanding.
Gunnar Englund
www.gke.org
I'm not confident of the values I found
TIC226D: 63 Ohm (possibly, but unlikely damaged triac)
TIC226M: 630 Ohm (never used) (ten times more resistive. Not a typo)
Illegible power triac: 32 Ohm
Could someone back them up ?
Adding to Skogsgurra's answer: the resistance must be measured between MT1 and gate, ignoring MT2
