Stainless Steel Tubing Supplier
I just spent an hour searching the web for a hydraulic tubing supplier in the North East (well anywhere I guess ... no local supplier so it will have to come in UPS). I got 10 pages deep on a Google search and gave up.
So far the only one that jumps out is McMaster Carr. Seamless .. $35 for 6 ft ... welded $19 for six feet.
I don't know if there is a difference .. both have the same rating and both say they can be bent.
I need just a small amount ( say 20 ft ) of 1/2" OD with .049 wall.
It needs to be stainless to get a rating above 3000 psi ( 1010 is only about 2300 psi ).
Thanks ..... Mike
RE: Stainless Steel Tubing Supplier
Try Parker and/or Swagelok
Go to .065 wall in carbon steel.
Ted
