PACSystems Rx3i PLCs Global Communication Fault
Hi there,
Here ins Ok Tedi Mining Limited
We have 4X Rx3i PLCs that talk to each other using Ethernet Global Data (EDG) Exchange
At the moment we a facing the issue of Global Communication(EDG) Failure
What the are the cause of this fault and where should I look at-PLC hardware or fiber optic cable?
Appreciate your assistance
Chris
RE: PACSystems Rx3i PLCs Global Communication Fault
First make sure that all of your CPUs and Ethernet modules if used have the latest firmware. If that does not help the situation get a monitoring software like www.Wireshark.org to try to narrow down where the problems are coming from.
I would bet on the cabling be it FO or CU.
Thanks dV8r (Electrical)
@ danw2, that link is to a very old manual. The latest one for this can be found on the GE web site here:
Ethernet Comms Manual GFK-2224
