Wing Leveling Using Earth Magnetism
Dacades ago I read about experiments using the Earth's magnetic field to keep the wings level on a high altitude gas powered model airplane. It would seem to have application to today's UAVs our military is using in the Middle East.
Does anyone have knowledge on how to mechanize such a system?
W. D. Allen Sr.
ballensr@adelphia.net
end
W. D. Allen Sr.
end
RE: Wing Leveling Using Earth Magnetism
The currently accepted means of measuring magnetic field for this type of application is a modification of a fluxgate compass, which has a basic accuracy no better than 0.1 deg.
The inertial nav system on a UAV such as Predator would be accurate to better than 0.001 deg.
Since the Earth's field can vary drastically over short distances, a fluxgate compass would need to be compensated, while the inertial nav system is immune to this.
TTFN
WDA
The inertial attitude gyro is a mandatory requirement, and it tells you absolute roll relative to earth, so there is no need for any other roll indicator.
TTFN
wether it works on not, what do you plan to do when the poles flip or when you fly south over the poles?
Shows you the angle of dip of the earth's magnetic field. In the USA your plane will be flying at around 70 degrees to the horizontal when flying East West!
Cheers
Greg Locock
A similar attitude control approach should work for today's military and civilian UAVs, precluding the need for attitude gyros.
WDA
end
TTFN
