Track Cursor Location
Hi All,
I just started using NX10
I use track cursor while creating curves, I looked under....
Preferences > User Interface > Options > Tracking Bar
Selected the Check box...
But the Tracking Dialog doesn't appear.
Am I missing something
Cheers
Automotive
Germany
NX10
RE: Track Cursor Location
I would suggest that you enter Track Cursor into your Command Finder and see what information it gives you.
If it is turned off it will tell you.
no results found
Automotive
Germany
NX10
I assume that we are talking about the "tracking bar" that shows up in the basic curves command.
If so, start the basic curves command, then go to menu -> preferences -> user interface -> layout and click on the "reset window position" button. The key is to start the basic curves command first and not to close it before changing the user interface option.
www.nxjournaling.com
Got it, many thanks...
Automotive
Germany
NX10
