"Unfired Steam Boiler" vs. "Power Boiler"
The state of Tennessee desires to classify our Waste Heat Boilers as "Power Boilers". The subject boilers cools process gas which consists of SO2 for the purpose of making 450# steam. As an organization, we wish to challenge this classification, and categorize the subject boilers as "Unfired Steam Boilers". I am looking for a reference, book, web site that elaborates on the design specifics, requirements, provides examples and/or technical definition of an "Unfired Steam Boiler". With regards to classification, I have researched ASME Section I and VIII code, and the definitions don't appear to be very detailed. There seems to be a little subjectivity in the interpretation of “Power Boiler” vs. “Unfired Steam Boiler”. We would like to eliminate some of this ambiguity by locating as much information as possible.
RE: "Unfired Steam Boiler" vs. "Power Boiler"
As UK consultants we have in the past been offered unfired waste heat boilers designed in accordance with both ASME I and ASME VIII and have accepted both. This is because in ASME VIII there is a clause that refers to compliance with certain clauses of ASME I that refer to matters like drum level indication etc. As a consequence, I cannot see any advantage in classifying unfired boilers as either ASME VIII or ASME I.
athomas236
How does your boiler/machinery insurance company address the matter?
You can believe the Chief Boiler Inspector of Tenn and most of his deputies frequent this site.
Perhaps you should discuss it with him privately.
I spent many years(over 30) designing and manufacturing Heat Recovery Boilers, and the rule we always followed was that if the hot gasses are the products of combustion, then it is a Section I boiler.
It doesn't matter if the combustion takes place a few feet from the tubes, or hundreds of feet from the tubes.
Jack Hardie
Thanks for the information about some States policy to ASME Section I. In the international market we tend to use the whole of ASME without any deletions or additions. Your information makes me wonder if this is a completely satisfactory policy.
athomas236
The ASME and NBIC codes came about when this country was experiencing castastrophic losses from boiler explosions. Nearly every page of those codes are written in blood...And the boiler owner, if he escaped the carnage, survived to suffer tremendous business losses and additional liability from dead/injured survivors and their families.
Yet everyday of my inspection history, I had to watch for 'organizations' trying to destroy themselves by curcumventing the law in an attempt to keep steaming.
Sorry Charlie, boiler inspection is a fact of life. And the sooner you embrace it, the sooner you welcome it, the sooner you plan it into your other shutdown maintenance requirements, the sooner you will benifit from it.
If all it is and has been to you is trouble, then take it upon yourself to make the event productive. Discoveries made during inspection can be worth their weight in $$$. Inspection can reveal how effective your maintenance and chemical treatment plans are. Inspection can help you plan shutdowns rather than react to them.
The old saying goes, "You get what you inspect, not what you expect."
I love those old sayings, I hate they must forever be repeated.
As professionals, we are here to protect the public, not to please the boss and temporarily line our pockets, or matter of factly, feed our families on the blood of someone elses.
Suppose the local hospital decided, rather than close their doors, cut cost by sharing used needles? Please close the doors.
You're welcome Sir,
I'm sitting directly under a DFT containing 2000 gallons of water at 227 F, 5 PSI....I'm scared of it. It hasn't undergone an internal inspection since it was placed in service back in 1986. The reason? It's not "required" in this state.
I again today waved additional evidence of catastrophic DFT failures at my boss. He finally agreed that it must be inspected.
Am I an alarmist? I don't think so. I lived for many years inside a pressure vessel. Outside that shell was all the water in the world pressing in on me at 700 PSI. I never recall being scared then, but I am now.
In the early 80's, industry experienced several DFT failures. People died. Once the world woke up to the danger, they began to inspect their DFT's. Over half of the vessels inspected revealed severe cracking. All were either repaired or condemned. Well, not all....I'm sitting under one that people neglected to inspect.
on the subject of the unfired steam boilers:
they are power boilers!.-
It is there in the preamble/first pages of the sec. I of the ASME Code, it just hard to find and read.
ER
Usually if the heat is from the products of combustion, it is a power boiler, but not always. Somes HRSG's may at times be considered unfired .
A power boiler requries an annual inspection, . An unfied boiler fo section VIII must meet more stringent rules for vessels, such as ad'l X-ray, PWHT, and impact testing. And of course section VIII recognizes fatigue damage while section I is blissfully silent on this issue.
In this particular case, the vessel was already constructed to the rules of Power Boilers (Section I) so the jurisdiction was quite correct in requiring it to be treated as a Section I boiler. But Section VIII is a perfectly legitimate choice for original construction (which the jurisdition understood, per the final comment from chbake). That being said, you still need to comply with the requirements of the local jurisdiction.
