NX10 Simple Clearance Check
In NX 7.5 there was a menu
Analysis - Assembly Clearance - Simple Clearance Check
which was very handy quick way to do a check on an assembly. Can't find this option in NX10. Is it still there?
thanks
Steve
RE: NX10 Simple Clearance Check
ofcourse is still there:
use command finder: clearance analysis
or go to analysis->assembly clearance...
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
www.studiotreccani.com
In NX7.5 there were 3 ways to check for assembly clashes/clearances:
Analysis - simple interference
Analysis - Assembly Clearance - Clearance Set
The second one is now gone in NX10 and the others are still there.
thanks
Steve
