View dependent Edit on assembly level NX8,5
I'm currently working on an assembly in NX8.5. I want to show some hidden lines on an assembly with the view dependent edit-function.
On a simple body part it seems to work: (RMB>Style> hidden lines checked, dashed -> view dependent edit > Edit entire objects> line font changed, apply and finally hidden lines set to invisible. Hooray Cheer Cheer
I've tried the same for a multi-body part or assembly and than NX it seems to ignore the edits. The edited lines show up in the view dependent edit, but as soon as I reset the hidden lines to invisible they are gone.
Is there a setting I should (not) check or is it a common issue in 8,5??
with regards
RE: View dependent Edit on assembly level NX8,5
Check if the views are of type exact...Then it doesn't work in NX8.5
views should be of Pre-NX8.5 type
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
