Display hidden note with attribute string in template file
I'm editing a template.
What I do:
I create a note, fill in the note with an attribute string. When I do this the note is hidden. I can't select it, si i can't correct it.
When I use the template the value of the attribute is shown on the drawing. Exactly as I wanted. But it was the wrong one.
How to make the note in the template file visible so I can edit it?
RE: Display hidden note with attribute string in template file
Solved.
I had contact with GTAC and they helped me perfectly.
Solution: Add temporarily a model in the template drawing with all attributes values. The attribute value will appear in the drawing and I was able to delete them.
