ASTM A36 chemical requirement
RE: ASTM A36 chemical requirement
Thank you metengr,
So what should be max amount of manganese allowed in material?
https://about.me/jdmech
It depends on the carbon content used for the plate to establish the required minimum mechanical properties. The Mn content will be as necessary so I can't give you an acceptable range.
Actually,the manganese (and carbon) limits are dependent on product form and, if plate, the width and thickness.
